TwinTurbo.NET: Nissan 300ZX forum - Re: R12 to R134a conversion
pkz293
on July 11, 2020 at 9:07 PM
posted by Kvert
on July 11, 2020 at 04:05 PM
with the system off, and you adjust the cabin temperature, can you hear the blend door moving at all?
Sounds from pressures like the compressor is cycling on, you did check for that correct? Is your condenser crudded up with dirt and debris?
Kvert
16:05:50 07/11/20
Re: R12 to R134a conversion -
pkz293
21:07:30 07/11/20
Re: Re: R12 to R134a conversion
Kvert
10:25:32 07/12/20
Check lines going to txv at firewall.
mrchips
08:44:08 07/12/20
Update: miracles happen ...
Kvert
12:07:17 07/12/20
Mine definitely cools fine when the car is in motion.
ZaXxon
13:45:24 07/14/20
Just something you probably do. But, do you turn on the
SirpriZ
22:11:22 07/14/20
I do not, I'll give it a try. (n/m)
ZaXxon
08:37:11 07/15/20
